I recently upgraded to version 7.4.156 and I need to draw people to a really annoying change they’ve made.
When going into port manager and changing any port to access just a single VLAN, they’ve changed the terminology from Native and Tagged VLANs to “Primary Network” and “Traffic Restriction” and by default the “Traffic Restriction” is off. Thus you think you’ve set a port to access a specific VLAN, but in fact what you’ve done is setup a trunk port and only set the native vlan on that port.
This caused me some issues this week as I didn’t notice the traffic restriction option was turned off, and in fact I assumed this was some weird layer 3 type traffic control so ignored it. This inadvertently turned my access port into a trunk port, which then tried to trunk all my traffic up to a Cisco switch which I only wanted on 1 specific VLAN. Annoyingly what happened next was catastrophic. Because I had 2 ports setup from 2 different switches into that Cisco switch, and because both of those ports didn’t have the traffic restriction option turned on, it then tried to utilize that link as a trunk between the 2 unifi switches, and RSTP disabled to true trunk I had in place, thus severing one portion of our network from the other.
I wanted to draw people to this change before someone else falls victim of this.
Why they’ve strayed away from an industry standard terminology of “Tagged” and “Untagged/Native” VLAN’s and opted for this weird naming convention, I have no idea.
Other annoying changes:
Port profiles are now Ethernet Profiles, and there’s no longer an “All” or per VLAN options anymore.
If you want to use “All” you have to select a VLAN for the primary network and turn off the Traffic Restriction option.
This also means that the number of port profiles (Ethernet Profiles) you now have will have reduced.
One good change is that you can now disable a port easily without changing it’s port profile. ![]()
Full list of changes are on their releases page:
https://community.ui.com/releases/UniFi-Network-Application-7-4-156/15ac6260-9cd1-4ac3-a91c-4880c1c87882
