I tested TrueNAS-13.0-U3.1 against TrueNAS-SCALE-22.12.0 by following this process:
- Loaded TrueNAS Core
- Created NFS & iSCSI Shares
- Connected to XCP-NG host
- Ran Phoronix Benchmarks from VM on XCP-NG
- Created SMB share
- Used Crystaldisk benchmark from Windows to share
- Did in place upgrade to TrueNAS Scale
- Ran Phoronix Benchmarks from the same VM on XCP-NG
Hardware AMD Ryzen 5 5600G 64GB ZFS 1 x RAIDZ2 SSD Sata Drives
Flexible IO Tester 3.29
Random Read Block Size: 1MB
MB/s > Higher Is Better
TrueNAS 13 NFS ............ 770 |=================================
TrueNAS 13 iSCSI .......... 475 |====================
TrueNAS Scale 22.12 NFS ... 1044 |=============================================
TrueNAS Scale 22.12 iSCSI . 794 |==================================
IOPS > Higher Is Better
TrueNAS 13 NFS ............ 766 |=================================
TrueNAS 13 iSCSI .......... 471 |====================
TrueNAS Scale 22.12 NFS ... 1041 |=============================================
TrueNAS Scale 22.12 iSCSI . 791 |==================================
Random Read Block Size: 4KB
TrueNAS 13 NFS ............ 231 |==========================================
TrueNAS 13 iSCSI .......... 252 |==============================================
TrueNAS Scale 22.12 NFS ... 180 |=================================
TrueNAS Scale 22.12 iSCSI . 226 |=========================================
TrueNAS 13 NFS ............ 59007 |========================================
TrueNAS 13 iSCSI .......... 64487 |============================================
TrueNAS Scale 22.12 NFS ... 46100 |===============================
TrueNAS Scale 22.12 iSCSI . 57967 |========================================
Random Read Block Size: 8MB
TrueNAS 13 NFS ............ 860 |====================================
TrueNAS 13 iSCSI .......... 541 |=======================
TrueNAS Scale 22.12 NFS ... 1069 |=============================================
TrueNAS Scale 22.12 iSCSI . 815 |==================================
TrueNAS 13 NFS ............ 104 |=====================================
TrueNAS 13 iSCSI .......... 64 |=======================
TrueNAS Scale 22.12 NFS ... 130 |==============================================
TrueNAS Scale 22.12 iSCSI . 98 |===================================
Random Write Block Size: 1MB
TrueNAS 13 NFS ............ 654.00 |=============================
TrueNAS 13 iSCSI .......... 957.00 |===========================================
TrueNAS Scale 22.12 NFS ... 876.10 |=======================================
TrueNAS Scale 22.12 iSCSI . 647.94 |=============================
TrueNAS 13 NFS ............ 650 |===============================
TrueNAS 13 iSCSI .......... 953 |==============================================
TrueNAS Scale 22.12 NFS ... 872 |==========================================
TrueNAS Scale 22.12 iSCSI . 644 |===============================
Random Write Block Size: 4KB
TrueNAS 13 NFS ............ 202.00 |=======================
TrueNAS 13 iSCSI .......... 377.00 |===========================================
TrueNAS Scale 22.12 NFS ... 184.00 |=====================
TrueNAS Scale 22.12 iSCSI . 189.07 |======================
TrueNAS 13 NFS ............ 51713 |========================
TrueNAS 13 iSCSI .......... 96483 |============================================
TrueNAS Scale 22.12 NFS ... 47120 |=====================
TrueNAS Scale 22.12 iSCSI . 48383 |======================
Random Write Block Size: 8MB
TrueNAS 13 NFS ............ 680 |==============================
TrueNAS 13 iSCSI .......... 845 |=====================================
TrueNAS Scale 22.12 NFS ... 1022 |=============================================
TrueNAS Scale 22.12 iSCSI . 782 |==================================
TrueNAS 13 NFS ............ 81 |==============================
TrueNAS 13 iSCSI .......... 102 |======================================
TrueNAS Scale 22.12 NFS ... 124 |==============================================
TrueNAS Scale 22.12 iSCSI . 94 |===================================
Random Read Block Size: 128KB
TrueNAS 13 NFS ............ 459 |====================
TrueNAS 13 iSCSI .......... 467 |====================
TrueNAS Scale 22.12 NFS ... 1035 |=============================================
TrueNAS 13 NFS ............ 3668 |====================
TrueNAS 13 iSCSI .......... 3735 |====================
TrueNAS Scale 22.12 NFS ... 8274 |=============================================
TrueNAS Scale 22.12 iSCSI . 6324 |==================================
Random Write Block Size: 128KB
TrueNAS 13 NFS ............ 624 |============================
TrueNAS 13 iSCSI .......... 876 |=======================================
TrueNAS Scale 22.12 NFS ... 1007 |=============================================
TrueNAS Scale 22.12 iSCSI . 697 |===============================
TrueNAS 13 NFS ............ 4992 |============================
TrueNAS 13 iSCSI .......... 7003 |=======================================
TrueNAS Scale 22.12 NFS ... 8051 |=============================================
TrueNAS Scale 22.12 iSCSI . 5573 |===============================
Sequential Read Block Size: 1MB
TrueNAS 13 NFS ............ 979 |==========================================
TrueNAS 13 iSCSI .......... 898 |======================================
TrueNAS Scale 22.12 NFS ... 1051 |=============================================
TrueNAS Scale 22.12 iSCSI . 801 |==================================
TrueNAS 13 NFS ............ 976 |==========================================
TrueNAS 13 iSCSI .......... 894 |======================================
TrueNAS Scale 22.12 NFS ... 1047 |=============================================
TrueNAS Scale 22.12 iSCSI . 798 |==================================
Sequential Read Block Size: 4KB
TrueNAS 13 NFS ............ 433 |==============================================
TrueNAS 13 iSCSI .......... 383 |=========================================
TrueNAS Scale 22.12 NFS ... 369 |=======================================
TrueNAS Scale 22.12 iSCSI . 344 |=====================================
TrueNAS 13 NFS ............ 110927 |===========================================
TrueNAS 13 iSCSI .......... 98107 |======================================
TrueNAS Scale 22.12 NFS ... 94533 |=====================================
TrueNAS Scale 22.12 iSCSI . 88200 |==================================
Sequential Read Block Size: 8MB
TrueNAS 13 NFS ............ 1012 |==========================================
TrueNAS 13 iSCSI .......... 522 |======================
TrueNAS Scale 22.12 NFS ... 1077 |=============================================
TrueNAS Scale 22.12 iSCSI . 810 |==================================
TrueNAS 13 NFS ............ 123 |===========================================
TrueNAS 13 iSCSI .......... 62 |======================
TrueNAS Scale 22.12 NFS ... 131 |==============================================
Sequential Write Block Size: 1MB
TrueNAS 13 NFS ............ 669 |===============================
TrueNAS 13 iSCSI .......... 919 |==========================================
TrueNAS Scale 22.12 NFS ... 995 |==============================================
TrueNAS Scale 22.12 iSCSI . 713 |=================================
TrueNAS 13 NFS ............ 665 |===============================
TrueNAS 13 iSCSI .......... 915 |==========================================
TrueNAS Scale 22.12 NFS ... 991 |==============================================
TrueNAS Scale 22.12 iSCSI . 710 |=================================
Sequential Write Block Size: 4KB
TrueNAS 13 NFS ............ 308 |======================
TrueNAS 13 iSCSI .......... 635 |==============================================
TrueNAS Scale 22.12 NFS ... 366 |===========================
TrueNAS Scale 22.12 iSCSI . 386 |============================
TrueNAS 13 NFS ............ 78933 |=====================
TrueNAS 13 iSCSI .......... 162667 |===========================================
TrueNAS Scale 22.12 NFS ... 93700 |=========================
TrueNAS Scale 22.12 iSCSI . 98733 |==========================
Sequential Write Block Size: 8MB
TrueNAS 13 NFS ............ 683 |=================================
TrueNAS 13 iSCSI .......... 964 |==============================================
TrueNAS Scale 22.12 NFS ... 949 |=============================================
TrueNAS Scale 22.12 iSCSI . 697 |=================================
TrueNAS 13 NFS ............ 82 |================================
TrueNAS 13 iSCSI .......... 117 |==============================================
TrueNAS Scale 22.12 NFS ... 115 |=============================================
TrueNAS Scale 22.12 iSCSI . 83 |=================================
Sequential Read Block Size: 128KB
TrueNAS 13 NFS ............ 977 |==========================================
TrueNAS 13 iSCSI .......... 589 |=========================
TrueNAS Scale 22.12 NFS ... 1050 |=============================================
TrueNAS Scale 22.12 iSCSI . 789 |==================================
TrueNAS 13 NFS ............ 7810 |==========================================
TrueNAS 13 iSCSI .......... 4706 |=========================
TrueNAS Scale 22.12 NFS ... 8401 |=============================================
TrueNAS Scale 22.12 iSCSI . 6310 |==================================
Sequential Write Block Size: 128KB
TrueNAS 13 NFS ............ 656.0 |==============================
TrueNAS 13 iSCSI .......... 738.4 |==================================
TrueNAS Scale 22.12 NFS ... 968.0 |============================================
TrueNAS Scale 22.12 iSCSI . 738.0 |==================================
TrueNAS 13 NFS ............ 5247 |===============================
TrueNAS 13 iSCSI .......... 5903 |==================================
TrueNAS Scale 22.12 NFS ... 7741 |=============================================
TrueNAS Scale 22.12 iSCSI . 5902 |==================================
Phoronix page link
