Alright so here is another one about my pfSense and TP-Link Experience.
At the moment I am using the following equipment;
pfSense 2.4.5 (1 Ethernet Jack, Trunked using switch)
TP-Link SG108E Unmanaged Pro
TP-Link TL-WA801ND (AP)
The Switch should support VLANs however when ever I assign a VLAN to a port it picks up an IP but says no internet connection then when I set the AP to multi SSD mode and configure SSID’s and VLANS I connect to the guest network which should have the IP of 192.168.3.x however it picks up the IP 192.168.0.x.
hi
I used similar setting with pfsense 2.4.5 vlan 122 config in pfsense and Switch TL-SG108E and AP TP-Link EAP 110.
but pfsense not DHCP Leases on vlan 122!
my config
im see video for config
if you have a device connected to other SSID is a laptop/Desktop, you can check by running command ping 8.8.8.8 and ping google.com. if ping 8.8.8.8 works and ping google.com does not then its a DNS issue.
Thanks, I pinged it and nothing so I went on to google and searched something so I could run Windows Diagnostics and it said it was a DNS error. In the DHCP server settings I have DNS configured to Primary: 8.8.8.8 Secondary: 8.8.4.4 this is the same for all VLANs including the one that works.
All networks working expect the Guest one. Can someone advise me on who to configure the firewall for the guest network. Also how to setup a captive portal as it does not work upon connecting to the network.
The TP-Link TL-WA801ND access point does not support vLANS but it does have multi-SSID I do not think these are the same things. The TP-Link SG108E also does not support vLANS.
With your set up you’ll basically only get one LAN regardless of what you do on PfSense.
There are cheap netgear switches and TP-Link Access Points that you can acquire for not much money.
You are wrong. They both support VLANs because I contacted TP-LINK and asked. Also if they don’t support VLANs how come I have them setup and working right now?
