Hello,
I’ve watched 3 of your videos about HAProxy and I thank you. They’ve help me greatly and I really like your your depth of knowledge and the additional pointers. I feel like I’m so close, but…
There are a lot of moving pieces so I’ll go with the most obvious first. I can currently access servers configured with HAProxy from inside my LAN with https, full domain names, and with proper valid certs (the wildcard), but when I try it from my phone sans wifi, OTA, no go. It says:
This site can't be reached. - dns_probe_finished_nxdomain
I think I’ve done it all, but something’s just.not.right!
I’m now using Digital Ocean for free DNS although I tried CloudFlare first and because of lack of progress, I switched to DO to be more in line with your setup. I now have dns records like this:
- A - ddns.example_com which is working for my pfsense dynamic dns. I set it to 0.0.0.0 - within minutes it was set to provider IP address and ddns client is green in pfsense
- A - nextcloud.example_com - pointing to my ddns IP
- A - gitlab.example_com - pointing to my ddns IP
- A - photos.example_com’- pointing to my ddns IP
I have a wildcard cert: *.example_com - validated by acme green screen
Backends
- I have 3 backends: nextcloud, gitlab, photos.
- All are VMs running in a KVM server with registered DHCP addresses, and
- defined with address+port and all use port 80.
- They also have a CA (Acmecert) and a client certificate (the same wildcard) defined for each.
Frontend
- I have all 3 backends defined in a single frontend.
- It’s listening on my WAN (IPv4), port 433,
- type: http / https(offloading)
The ACL is configured:
- name: nextcloud_acl, host matches nextcloud.example_com
- name: gitlab_acl, host matches gitlab.example_com
- name: photos_acl, host matches photos.example_com
Next actions:
- Use backend nextcloud, condition acl name: nextcloud_acl
- Use backend gitlab, condition acl name: gitlab_acl
- Use backend photos, condition acl name: photos_acl
- I added the extra _acl so I remembered they’re different but must match.
- SSL Offloading Certificate is: Wildcard cert
Oh, and I have a WAN rule - IPv4 TCP, Source: any, Destination: 443.
Please, for the love of mercy, what am I missing? ![]()
Any tips appreciated.
[dinged because I’m a beginner w/ limit of 2 links, so example_com… I’m sure you’ll understand]
