ZFS Drive Layouts Explained: Choosing the Right Design for Your Workload
ZFS Metadata & Cache Devices
Component What It Actually Does Helps Most With Common Use Cases When It Usually Does Nothing
ARC ( RAM Memory) Primary read cache for data and metadata All workloads Everything CACHE ALL THE THINGS
VDEV Count Determines IOPS and parallelism Random I/O, concurrency VMs, DBs, busy SMB
Mirror VDEVs Lowest latency, highest IOPS Random I/O Virtualization, databases, SMB Large-file streaming
RAIDZ (Z1/Z2/Z3) Capacity-efficient parity Sequential throughput Media, backups, archives High-IOPS workloads
SLOG Accelerates sync writes only Sync write latency NFS VMs, databases SMB, media, backups
Special / Metadata VDEV Stores metadata + small blocks Metadata-heavy I/O VMs, SMB, small files Large media files
L2ARC Secondary read cache Repeated reads VM boot storms Workloads where the same files are not requested again
Deduplication (DEDUP) Eliminates duplicate blocks globally Space efficiency VM clones, VDI images, Cloning Data Media, backups, mixed data
Deduplication – Special Notes (Read Before Enabling)
Requirement Why It Matters
Very high RAM DDT must fit in memory for performance
Predictable data Random data defeats dedupe
Metadata performance DEDUP is metadata-heavy
Careful capacity planning DDT grows fast and is hard to remove
Storage Efficiency & Performance
Klara Systems: RAIDZ, Mirrors, and Hybrid Configurations
Klara Systems: Understanding ZFS vdev Types
Klara Systems: dRAID
