I realize this may be a stretch, but does anyone have experience installing ZeroTier on a QNAP NAS? I’ve looked on the ZeroTier site, but can’t find the commands to get it installed via the CLI.
Thanks,
Sean
Thanks,
Sean
I figured it out. I copied the desired installer from here…
Then, installed via manual install in the QNAP App Center.
@SKTC_Sean is it working well?
Chris
@chrisfonte - it is! The installation was quick and easy (once I figured it out). Then, I used ssh to get to the CLI and run the zerotier-cli join command. Authorized via the web interface and I was off and running. I love that zerotier makes devices accessible via .local
