I’m trying to build XO from source following the guide in this forum, using Debian 11 and I’ve tried Ubuntu 22 as well. I keep getting failures from Yarn when running xo-install.sh
and I’m not sure what’s going on, I have network connectivity and can connect to the hosts with curl just fine, but when I try running yarn by myself I get the results listed below:
root@xo:/opt/xo/xo-src/xen-orchestra# yarn --verbose --network-timeout 100000
yarn install v1.22.19
verbose 1.501009769 Checking for configuration file "/opt/xo/xo-src/xen-orchestra/.npmrc".
verbose 1.53677986 Checking for configuration file "/usr/local/share/.npmrc".
verbose 1.53902741 Checking for configuration file "/usr/etc/npmrc".
verbose 1.54064482 Checking for configuration file "/root/.npmrc".
verbose 1.542899475 Checking for configuration file "/opt/xo/xo-src/xen-orchestra/.npmrc".
verbose 1.543689538 Checking for configuration file "/opt/xo/xo-src/.npmrc".
verbose 1.545135563 Checking for configuration file "/opt/xo/.npmrc".
verbose 1.546317316 Checking for configuration file "/opt/.npmrc".
verbose 1.549051488 Checking for configuration file "/opt/xo/xo-src/xen-orchestra/.yarnrc".
verbose 1.549953511 Checking for configuration file "/usr/local/share/.yarnrc".
verbose 1.550974055 Checking for configuration file "/usr/etc/yarnrc".
verbose 1.585869182 Checking for configuration file "/root/.yarnrc".
verbose 1.587119015 Checking for configuration file "/opt/xo/xo-src/xen-orchestra/.yarnrc".
verbose 1.588528886 Checking for configuration file "/opt/xo/xo-src/.yarnrc".
verbose 1.590259022 Checking for configuration file "/opt/xo/.yarnrc".
verbose 1.592178206 Checking for configuration file "/opt/.yarnrc".
verbose 1.647374917 current time: 2023-03-27T00:25:32.298Z
verbose 2.548519244 Performing "GET" request to "https://yarnpkg.com/latest-version".
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
verbose 13.948161868 Performing "GET" request to "https://registry.yarnpkg.com/@babel/parser/-/parser-7.21.2.tgz".
verbose 14.051117467 Performing "GET" request to "https://registry.yarnpkg.com/@babel/core/-/core-7.21.0.tgz".
verbose 14.05817095 Performing "GET" request to "https://registry.yarnpkg.com/@ampproject/remapping/-/remapping-2.2.0.tgz".
verbose 14.101632039 Performing "GET" request to "https://registry.yarnpkg.com/@babel/generator/-/generator-7.21.1.tgz".
verbose 14.144317296 Performing "GET" request to "https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.18.6.tgz".
verbose 14.150955639 Performing "GET" request to "https://registry.yarnpkg.com/@babel/helper-compilation-targets/-/helper-compilation-targets-7.20.7.tgz".
verbose 14.156931278 Performing "GET" request to "https://registry.yarnpkg.com/@babel/helpers/-/helpers-7.21.0.tgz".
info There appears to be trouble with your network connection. Retrying...
verbose 117.00473677 Performing "GET" request to "https://yarnpkg.com/latest-version".
verbose 235.923521572 Performing "GET" request to "https://registry.yarnpkg.com/@babel/parser/-/parser-7.21.2.tgz".
verbose 235.92539328 Performing "GET" request to "https://registry.yarnpkg.com/@babel/core/-/core-7.21.0.tgz".
verbose 235.927716298 Performing "GET" request to "https://registry.yarnpkg.com/@ampproject/remapping/-/remapping-2.2.0.tgz".
verbose 235.929980098 Performing "GET" request to "https://registry.yarnpkg.com/@babel/generator/-/generator-7.21.1.tgz".
verbose 235.931826416 Performing "GET" request to "https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.18.6.tgz".
verbose 235.933532925 Performing "GET" request to "https://registry.yarnpkg.com/@babel/helper-compilation-targets/-/helper-compilation-targets-7.20.7.tgz".
verbose 235.935321144 Performing "GET" request to "https://registry.yarnpkg.com/@babel/helpers/-/helpers-7.21.0.tgz".
verbose 257.862901671 Performing "GET" request to "https://yarnpkg.com/latest-version".
verbose 341.055521309 Performing "GET" request to "https://registry.yarnpkg.com/@babel/parser/-/parser-7.21.2.tgz".
verbose 341.096523441 Performing "GET" request to "https://registry.yarnpkg.com/@babel/core/-/core-7.21.0.tgz".
verbose 341.098533637 Performing "GET" request to "https://registry.yarnpkg.com/@ampproject/remapping/-/remapping-2.2.0.tgz".
verbose 341.101644734 Performing "GET" request to "https://registry.yarnpkg.com/@babel/generator/-/generator-7.21.1.tgz".
verbose 341.103386652 Performing "GET" request to "https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.18.6.tgz".
verbose 341.104995921 Performing "GET" request to "https://registry.yarnpkg.com/@babel/helper-compilation-targets/-/helper-compilation-targets-7.20.7.tgz".
verbose 341.107174472 Performing "GET" request to "https://registry.yarnpkg.com/@babel/helpers/-/helpers-7.21.0.tgz".
Edit: I’ve tried with NPM, same result, but curl is able to access these URLs without issue:
root@xo:~# curl -I https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.18.6.tgz
HTTP/2 200
date: Mon, 27 Mar 2023 00:47:03 GMT
content-type: application/octet-stream
cf-ray: 7ae39eac3b4e3b29-IAD
accept-ranges: bytes
access-control-allow-origin: *
cache-control: public, must-revalidate, max-age=31557600
etag: "06bf74bedad2a91ac5c5950ee0d527a4"
last-modified: Mon, 27 Jun 2022 19:50:09 GMT
vary: Accept-Encoding
cf-cache-status: HIT
x-amz-replication-status: COMPLETED
server: cloudflare
