Working in my lab, I have XCP-ng all installed and happy, XCP-ng Central works to control my pool just fine, can launch Linux and Windows vms all good. I am ready for XO. I watch the youtube and follow the instructions, Debian 10, Debian 11, Ubuntu 22, with SSL without SSL. I have ran through the compile process about 5 times now, nuking each instance after then starting fresh. Each time appears to be completely successful. Every dang time, admin@admin.net and admin password invalid credentials.
What am I missing here?
There was a flaw that has been fixed, pull new source code and it should be good.
opened 04:21PM - 05 Jul 22 UTC
closed 12:34AM - 06 Jul 22 UTC
Hi, ran XenOrchestraInstallerUpdater on a fresh install of Debian 11.3.0 running… in a VM on Proxmox. Getting an error logging in using the credentials printed in the terminal after the installer finished (admin@admin.net/admin). Looking into the xo log, I am seeing this error:
Jul 05 11:58:06 xenorchestra xo-server[349]: 2022-07-05T15:58:06.601Z xo:authentification ERROR no available algorithm with id argon2id {
Jul 05 11:58:06 xenorchestra xo-server[349]: error: Error: no available algorithm with id argon2id
Jul 05 11:58:06 xenorchestra xo-server[349]: at getAlgorithmFromId (/opt/xo/xo-builds/xen-orchestra-202207051131/node_modules/hashy/index.js:189:11)
Jul 05 11:58:06 xenorchestra xo-server[349]: at getAlgorithmFromHash (/opt/xo/xo-builds/xen-orchestra-202207051131/node_modules/hashy/index.js:196:10)
Jul 05 11:58:06 xenorchestra xo-server[349]: at verify (/opt/xo/xo-builds/xen-orchestra-202207051131/node_modules/hashy/index.js:293:10)
Jul 05 11:58:06 xenorchestra xo-server[349]: at /opt/xo/xo-builds/xen-orchestra-202207051131/node_modules/hashy/index.js:33:22
Jul 05 11:58:06 xenorchestra xo-server[349]: at Promise._execute (/opt/xo/xo-builds/xen-orchestra-202207051131/node_modules/bluebird/js/release/debuggability.js:384:9)
Jul 05 11:58:06 xenorchestra xo-server[349]: at Promise._resolveFromExecutor (/opt/xo/xo-builds/xen-orchestra-202207051131/node_modules/bluebird/js/release/promise.js:518:18)
Jul 05 11:58:06 xenorchestra xo-server[349]: at new Promise (/opt/xo/xo-builds/xen-orchestra-202207051131/node_modules/bluebird/js/release/promise.js:103:10)
Jul 05 11:58:06 xenorchestra xo-server[349]: at verify (/opt/xo/xo-builds/xen-orchestra-202207051131/node_modules/hashy/index.js:32:9)
Jul 05 11:58:06 xenorchestra xo-server[349]: at default.checkUserPassword (file:///opt/xo/xo-builds/xen-orchestra-202207051131/packages/xo-server/src/xo-mixins/subjects.mjs:311:26)
Jul 05 11:58:06 xenorchestra xo-server[349]: at file:///opt/xo/xo-builds/xen-orchestra-202207051131/packages/xo-server/src/xo-mixins/authentication.mjs:53:20
Jul 05 11:58:06 xenorchestra xo-server[349]: at default._authenticateUser (file:///opt/xo/xo-builds/xen-orchestra-202207051131/packages/xo-server/src/xo-mixins/authentication.mjs:117:24)
Jul 05 11:58:06 xenorchestra xo-server[349]: at default.authenticateUser (file:///opt/xo/xo-builds/xen-orchestra-202207051131/packages/xo-server/src/xo-mixins/authentication.mjs:162:20)
Jul 05 11:58:06 xenorchestra xo-server[349]: at Strategy._verify (file:///opt/xo/xo-builds/xen-orchestra-202207051131/packages/xo-server/src/index.mjs:289:26)
Jul 05 11:58:06 xenorchestra xo-server[349]: }
As I'm not familiar with XenOrchestra, I'm not sure what my options are for getting logged in/creating a user/etc.
Installer:
$ sudo ./xo-install.sh
[sudo] password for rjlan:
Welcome to automated Xen Orchestra install
Following options will be used for installation:
OS: Debian 11
Basedir: /opt/xo
User: root
Port: 80
HTTPS: false
Git Branch for source: master
Following plugins will be installed: all
Number of previous installations to preserve: 3
Node.js and yarn auto update: true
Errorlog is stored to /home/rjlan/XenOrchestraInstallerUpdater/logs/xo-install.log-202207051131 for debug purposes
Depending on which installation is chosen:
Xen Orchestra configuration will be stored to /root/.config/xo-server/config.toml, if you don't want it to be replaced with every update, set CONFIGUPDATE to false in xo-install.cfg
Xen Orchestra Proxy configuration will be stored to /root/.config/xo-proxy/config.toml. Config won't be overwritten during update, ever
1. Install
2. Update
3. Rollback
4. Install proxy
5. Update proxy
6. Exit
: 1
[ok] Running apt-get update
[ok] Installing build dependencies, redis server, python, git, libvhdi-utils, lvm2, nfs-common, cifs-utils, curl, ntfs-3g, libxml2-utils
[ok] Installing apt-transport-https and ca-certificates packages to support https repos
[ok] Debian 10/11, so installing gnupg also
[ok] Installing node.js
[ok] Installing yarn
[ok] Enabling and starting redis service
[ok] Enabling and starting rpcbind service
[info] Creating missing basedir to /opt/xo
[info] Creating missing xo-builds directory to /opt/xo/xo-builds
[info] Fetching Xen Orchestra source code
[info] Creating install directory: /opt/xo/xo-builds/xen-orchestra-202207051131
[info] Installing Xen Orchestra from branch: master - commit: b96dd0160
[info] No 3rd party plugins to install
[info] xo-server and xo-web build takes quite a while. Grab a cup of coffee and lay back
[ok] Running installation
[ok] Installing plugins
[info] Fixing binary path in systemd service configuration file
[info] Adding WorkingDirectory parameter to systemd service configuration file
[info] Replacing systemd service configuration file
[info] Reloading systemd configuration
[info] Fixing relative path to xo-web installation in xo-server configuration file
[info] Activating modified configuration file
[info] Symlinking fresh xo-server install/update to /opt/xo/xo-server
[info] Symlinking fresh xo-web install/update to /opt/xo/xo-web
[info] Starting xo-server...
waiting for port to be open
WebUI started in port 80. Make sure you have firewall rules in place to allow access.
Default username: admin@admin.net password: admin
[info] Installation successful. Enabling xo-server service to start on reboot
HI Tom, Thanks for the reply. I will give it a shot… problem is I did all this testing today, looks like the code merged to master branch yesterday. I’ll keep digging in and open a bug if this continues.
Thanks again, appreciated.
Well following those instructions and switching to that specific branch, then running the update again fixed it up!
Thanks again Tom!
Not a problem, happy to hear you got it working.
