Hey folks,
I’ve been doing some testing, and it seems for whatever reason, that SMB is faster?
I thought NFS was better in linux to linux communication. Perhaps SMB is doing some sort of caching since the expected maximum speed for the Seagate Barracuda drives is about 150 MB/s, so I doubt it’s the drive speed that’s being saturated on every test run.
Was just curious what everyone else uses?
Results:
XOA writing to NFS share mount directory:
for i in {0..5}; do dd if=/dev/urandom of=testfile.bin bs=1M count=1000; done
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 8.36581 s, 125 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 10.0539 s, 104 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 9.31783 s, 113 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 8.67909 s, 121 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 8.96784 s, 117 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 8.65976 s, 121 MB/s
XOA writing to SMB share mount directory:
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 5.93853 s, 177 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 6.08925 s, 172 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 6.16683 s, 170 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 6.20099 s, 169 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 6.01749 s, 174 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 6.1518 s, 170 MB/s
Both devices (TrueNAS Scale VM, and a Debian Xen Orchestra VM) are connected over Netgate 4100 (2.5G) - And are technically running as VMs on the same hypervisor, but on different VLANs, so all communication has to go over pfsense.
Iperf3 results (TrueNAS as client, XOA as server):
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-30.00 sec 3.09 GBytes 884 Mbits/sec 44 sender
[ 5] 0.00-30.06 sec 3.09 GBytes 882 Mbits/sec receiver
[ 7] 0.00-30.00 sec 1.61 GBytes 462 Mbits/sec 56 sender
[ 7] 0.00-30.06 sec 1.61 GBytes 461 Mbits/sec receiver
[ 9] 0.00-30.00 sec 1.72 GBytes 491 Mbits/sec 15 sender
[ 9] 0.00-30.06 sec 1.71 GBytes 490 Mbits/sec receiver
[ 11] 0.00-30.00 sec 1.74 GBytes 500 Mbits/sec 18 sender
[ 11] 0.00-30.06 sec 1.74 GBytes 498 Mbits/sec receiver
[SUM] 0.00-30.00 sec 8.16 GBytes 2.34 Gbits/sec 133 sender
[SUM] 0.00-30.06 sec 8.15 GBytes 2.33 Gbits/sec receiver
TrueNAS - Seagate Barracuda 3.5" 2TB - ST2000DM008; Raid 1
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 2.65334 s, 395 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 5.16069 s, 203 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 6.38631 s, 164 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 8.13018 s, 129 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 7.27549 s, 144 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 8.44536 s, 124 MB/s
dd if=/dev/urandom of=testfile.bin bs=1M count=5000
5000+0 records in
5000+0 records out
5242880000 bytes (5.2 GB, 4.9 GiB) copied, 33.8633 s, 155 MB/s
Anyways, the goal of my research: I use rsync to synchronize everything from those 2 raid drives to a Raspberry Pi with a 4TB WD Red Plus, and the ZFS lz4 compressed share with XOA backups on TrueNAS, has been having oddly slow transfer speeds to the RPi, just 25 MB/s.
Synchronizing all other shares seems normal, although I’m not sure if it’s the compression or something else, since that share is the one that gets the most writes to it daily, and is the biggest one out of all (1TB).
It’s definitely not the write speeds on the RPi (which should be about 175MB/s).
It’s definitely not the network link between TrueNAS and the RPi.
There doesn’t seem to be a lack of processing power, since neither TrueNAS, nor the RPi go above 30% CPU usage during the transfer.
So what the hell kind of trickery could it be?
RPi write speeds to the WD Red Plus 4TB (note how I used /dev/zero - RPi seems to be choking with /dev/urandom and giving me only about 45MB/s - Maybe this is a part of the bigger problem?):
for i in {0..5}; do dd if=/dev/zero of=testfile.bin bs=1M count=1000; done
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 5.94795 s, 176 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 7.87396 s, 133 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 7.91027 s, 133 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 8.24003 s, 127 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 8.2287 s, 127 MB/s
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB, 1000 MiB) copied, 8.21602 s, 128 MB/s
Iperf3 server results (TrueNAS as client, RPi as server): This is all good since the RPi only has a 1Gbit link
[ 5] 0.00-30.00 sec 616 MBytes 172 Mbits/sec 66 sender
[ 5] 0.00-30.09 sec 613 MBytes 171 Mbits/sec receiver
[ 7] 0.00-30.00 sec 589 MBytes 165 Mbits/sec 62 sender
[ 7] 0.00-30.09 sec 587 MBytes 164 Mbits/sec receiver
[ 9] 0.00-30.00 sec 486 MBytes 136 Mbits/sec 26 sender
[ 9] 0.00-30.09 sec 484 MBytes 135 Mbits/sec receiver
[ 11] 0.00-30.00 sec 1.64 GBytes 470 Mbits/sec 0 sender
[ 11] 0.00-30.09 sec 1.64 GBytes 469 Mbits/sec receiver
[SUM] 0.00-30.00 sec 3.29 GBytes 943 Mbits/sec 154 sender
[SUM] 0.00-30.09 sec 3.29 GBytes 938 Mbits/sec receiver
