Yep my fault I missed that. Are you updating the original configuration or are you modifying an existing backup configuration? If modifying existing, try to completely remove the job and recreate it.
Sounds like there is some configuration issue on your end. I am not running into any issues on the same commit as you. If no one else here has any more suggestions you might hit up the xcp-ng forums.
OK thanks. just for curiosity I’ll try another target OS for the remote. now it is unraid. if it works with truenas, that doesn’t solve my problem, but it may give new hints.
