rikmyr
September 22, 2022, 1:56am
1
I have a Delta Backup being saved to my TrueNAS box and from there cloud replication to Backblaze.
I want to restore a specific virtual machine to a totally separate instance of xen orchestra and xcp-ng.
I downloaded the delta backup from Backblaze, now is there a way to restore this delta backup to the new and separate instance of xcp-ng?
LTS_Tom
September 22, 2022, 10:02am
2
You point the new Xen Orchestra “Remote” (backups location) over to the place you downloaded the files.
rikmyr
September 22, 2022, 1:44pm
3
So I did that bun Xen Orchestra doesn’t see the backups for some reason.
LTS_Tom
September 22, 2022, 3:39pm
4
The remote in XO should point at \\YourServer\backups\ and in the root of that there should be a directory called xo-vm-backups
rikmyr
September 22, 2022, 3:54pm
5
Yeah that’s what I thought ,and that’s what I set up.
It just doesn’t see it for whatever reason.
rikmyr
September 22, 2022, 4:06pm
6
Okay, so I rebooted Xen Orchestra and then tried again and now the data is showing. Not sure if its a bug or what but anyways, appreciate your help & response @LTS_Tom !
