Hello,
So I am in the somewhat early stages of planning out a XCP-NG/XOA infrastructure deployment for both Production and UAT/Test environments.
The goal:
Move our currently externally hosted Microsoft Dynamics 2016 CRM and Website to our own infrastructure (this will save us $75k/y in hosting fee’s…). Along with a few other VM’s. So public DMZ is needed.
back story:
We were originally going to use 2x VMWare Essential licenses to manage the whole setup, but I then discovered XCP-NG and I’m keenly intrigued to try it out (all the additional functionality is hard to beat). So all the hardware was originally purchased with the intent to use VMware, so I might not have things optimally setup for XCP-NG, but that is why I’m here.
The hardware:
I had a killer opportunity to buy 6 servers for significantly cheaper then my original budget to buy 1 high end current Server (was looking at a single AMD Epyc based server, but could only afford 1 ~$23k).
4 x Dell R620s (128GB DDR3 Ram, E5-2660 V2, no HDD, 2/2 SFP+/RJ45G Nics)
2 x Dell 730xd’s (128GB DDR4, E5-2660 V3, no HDD, 4 SFP+/2 RJ45G). vendor only had 2!
Synology FS3400 with ~48TB and 1.6GB of NVMe Cache.
Mikrotik CRS317-1g-16s+RM (running purely in switch mode),
2 x Mikrotik CSS610-8G-2S+in (also running in switch mode),
Currently a compiled version of XO just to get setup, test the setup before committing to the enterprise license (and transferring the config to a proper licensed XOA).
All of these servers are interconnected with dual 10GB interfaces (still have to learn XO Networking) via a mikrotik crs317-1g-16s+rm purely for the VM traffic, and all actual vm network traffic will traverse a set of 2 x mikrotik css610-8g-2s+in each configured to do DMZ based traffic (Web and VPN), and all other network traffic will traverse a (to be replaced) Dlink DGS-1210-24P (we are re-using it for now, but will be replaced soon enough).
All of this traffic traverses a Fortigate firewall that is capable of handling a maxed out 1Gig fiber connection with all inspections enabled.
The question:
I’m just setting up my PROD/UAT Pools, and I was thinking:
Prod: 2 x R730XD’s and 2 x R620s
Uat: 2 x R620’s.
All VM storage will live on the Synology NAS using NFS/iSCSI (most NFS, SQL database will use iSCSI).
Will having mixed generations of servers cause problems for HA? (I understand XCP-NG will operate with the lowest CPU capabilities). I’m just not sure if there is other “hidden” problems that will arise, that isnt well documented.
The other thought I had, was doing a 2 x 2 x 2 setup:
Prod: 2 x R730’s
Prod-Backup: 2 x R620’s
UAT: 2 x R620’s.
With the idea that should “Prod” go down, all VM’s can be moved to Prod-Backup if needed (but somehow this seems… not the best use of hardware to me).
Second Question:
Does anybody have a good video link explaining how to properly setup each servers 10Gig interfaces to a specific vlan for vm traffic only, and then assign the other 1Gig interfaces as dedicated to a specific VM as needed (for my DMZ for example) ?
Third Question:
Does anybody know if you can transfer the entire config from a compiled XO setup, to a Licensed XOA server?
Looking forward to your recommendations.
