So I have an old Dell C6320. Lovely system, runs 4 nodes in 2 U, basically a bunch of fancy R630s. Love the thing. Runs proxmox, debian, and anything else I throw at it like a champ.
I decided to try running XCP-NG in the thing and see if I can get some extra use out of it. Well, on the first node I fire up, I’m hitting a solid 30-50% packet loss on the internal X520 NICs. 82599ES chipset. Onboard.
First I think there’s something wrong with the hardware and I go to research how much it would cost to replace a node. Too much for today. I switch to the Mellanox NICs in the Mezzanine slot, and keep going.
Well, I decide to get to the bottom of this, I create a simple debian 13 VM, and connect it to the Mellanox network bridge, and ping my internet gateway. Works fine. No packet loss.
Then I attach it to EITHER of the two X520 NICs and I get heavy packet loss, 30-50%. This is odd. But it gets odder.
To verify that it’s not a hardware problem, I configure the X520 NICs for PCI-E passthrough, and pass them through to the debian guest. I bring them up in the guest, and they work just fine. 0% packet loss.
Pass them back to the host, go through all the reboots, and then I get back the high packet loss rate.
In the dmesg output on the host, I see the following block every time packet loss happens.
[ 1507.783650] ixgbe 0000:81:00.1: removed PHC on eth1
[ 1507.855479] ixgbe 0000:81:00.1: Multiqueue Enabled: Rx Queue count = 8, Tx Queue count = 8 XDP Queue count = 0
[ 1507.892829] ixgbe 0000:81:00.1: registered PHC device on eth1
[ 1507.955588] ixgbe 0000:81:00.1 eth1: detected SFP+: 4
[ 1509.896477] ixgbe 0000:81:00.0: removed PHC on eth0
[ 1509.971228] ixgbe 0000:81:00.0: Multiqueue Enabled: Rx Queue count = 8, Tx Queue count = 8 XDP Queue count = 0
[ 1510.007199] ixgbe 0000:81:00.0: registered PHC device on eth0
[ 1510.072358] ixgbe 0000:81:00.0 eth0: detected SFP+: 3
[ 1511.435339] ixgbe 0000:81:00.1 eth1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[ 1513.451352] ixgbe 0000:81:00.0 eth0: NIC Link is Up 10 Gbps, Flow Control: RX/TX
Based on some reading, I’ve attempted both of these flags on the boot cli in an attempt to resolve the issue. pcie_aspm=off ixgbe.allow_unsupported_sfp=1,1 Absolutely no joy. Still getting high packet loss. Similarly, I tried installing the alternate drivers intel-ixgbe-alt. I’m near my witts end, and stumped as to what to try next. Why does XCP-NG hate my X520 NICs?
I do have some actual R630 systems I can test with, all with X520 NICs, but they’re in various state of missing CPUs or RAM or HDDs, and I’m currently recovering from a leg injury which means I can’t physically access them to get them into working order. If this is still unresolved in a few weeks when I can walk right, I’d be willing to test on a regular R630.
