So I’ve set up a VSAN on a VM running Starwinds VSAN software. I have it replicating between another VM on another host that’s also a VM running XCP-NG.
Does anyone know if there is a way to set up HA for the storage? If the storage on the primary VSAN node fails can XCP-NG somehow look for the storage on the other replicated VSAN node?
Thanks. I guess my question is more around multi-pathing storage for XCP-NG and in this case it would be active passive multi-pathing. The only option I can think of would to be to create a bonded network using a virtual switch but I haven’t bee able to play around with any of those settings yet.
