manoli
October 14, 2024, 7:20am
1
Hello guys,
on my XCP-ng Storage I have apart of ‘guest-tools.iso’ (that is normal)
also couple of ‘Old version of guest-tools.iso’ (viz. screenshot)
If try to destroy these extra “old versions” it fails with an error:
SR_OPERATION_NOT_SUPPORTED(OpaqueRef:51da4fff-c220-478f-843a-0e80ea9514d0)
Any idea how to get a rid of these? Can anyone give an advice?
Thank you and have nice day everyone.
LTS_Tom
October 14, 2024, 12:04pm
2
You probably have the ISO storage mounted as read only. By default the ISO for the tools are located in /opt/xensource/packages/iso and you can delete them manually via the command line.
manoli
October 14, 2024, 6:27pm
3
Thanks Tom for an advice,
well path is there but it shows only one file with latest guest tools iso:
[20:23 xcp-ng ~]# ls -lha /opt/xensource/packages/iso/
total 17M
drwxr-xr-x 2 root root 4.0K Oct 10 22:36 .
drwxr-xr-x 4 root root 4.0K Oct 10 22:36 ..
-rw-r--r-- 1 root root 17M Sep 20 15:06 guest-tools-8.3-12.xcpng8.3.iso
The other files that are shown on the picture in my initial post, surprisingly, are not there.
LTS_Tom
October 15, 2024, 11:27am
4
Then when on the “Host” tab of that SR you will have to look where that is pointing.
manoli
October 15, 2024, 3:13pm
5
It’s pointing exactly to path which we were talking about:
path: /opt/xensource/packages/iso
legacy_mode: true
Then hit the “Rescan Disks” button at the top of the that page you posted.
manoli
October 16, 2024, 4:15pm
7
Of-course I did that… It doesn’t help, reference to these files is stacked there even they are not present on the disk (or I cant find them).
manoli
October 16, 2024, 6:30pm
8
Found solution:
xe vdi-list sr-uuid=<uuid of XCP-ng Tools SR>
This will give you a list of VDIs. Find the one you want to remove and then forget it:
xe vdi-forget uuid=<uuid of VDI>
Rinse and repeat till all the “old guest tools” are removed and disappear from XO.
