Best to start with the specs/config:
Motherboard: ASRock Rack EP2C602-4L/D16
Processors: (x2): Xeon E5-2670 - 8 cores (HT) @ 2600MHz (16 cores total, 32 threads)
Memory (256GB): Kingston 16GB 2RX4 PC3-12800R DDR3 Reg ECC Server Memory SL16D316R11D4 (x16)
Storage1: (150GB RAID mirror): Local Storage
Storage2: (1TB ZFS mirror): vmpool1
Storage3: (1TB ZFS mirror): vmpool2
NAS1: (24 TB RAIDZ1): FreeNAS connected over 1Gbe connection (will upgrade to 10 Gbe with cards, later)
My question is how the ZFS works in this setup. I am trying to learn the fundamentals of ZFS and I’m having a difficult time wrapping my brain around some of the concepts.
Here are the steps I took to create the pools:
[08:39 xcpng ~]# zpool create -f -O compression=lz4 vmpool1 mirror ata-WDC_WD10EZEX-08WN4A0_WD-WCC6Y2LPY15U ata-SAMSUNG_HD103SJ_S246J90Z145111
[08:30 xcpng ~]# zpool create -f -O compression=lz4 vmpool2 mirror ata-WDC_WD1001FALS-00J7B0_WD-WMATV0071026 ata-WDC_WD1001FALS-00J7B0_WD-WMATV0071909
I then attached the zpools to the xcp-ng server as SRs:
[08:39 xcpng ~]# xe sr-create host-uuid=838a159e-642b-43dd-84b3-e7f8d7ac7f9a name-label=vmpool1 type=file device-config:location=/vmpool1
[08:39 xcpng ~]# xe sr-create host-uuid=838a159e-642b-43dd-84b3-e7f8d7ac7f9a name-label=vmpool2 type=file device-config:location=/vmpool2
What would be the next step?
Just start building VMs on the drives and let xcp-ng worry about how the storage is handled?
Or, should I create a large ZVOL on each of the 1TB drives and then start creating VMs using XO?
Or, should I have designated a different “type=file” parameter when creating the SRs and I should remove the SRs and reconnect them using a different argument for that parameter?
Any help would be greatly appreciated.
Thanks!
