I have a server with 5 - 2TB drives and 3 - 3TB drives. What’s the best way to configure the storage for xcp-ng? I was thinking of doing RAID 5 with the 2TB and RAID 0 with the 3TB or is it not a good idea to mix drive sizes?
Personally, I would never use RAID0. I think RAID5 is fine for the 2TB drives, but RAID6 would be better. You’ll have to use RAID 5 for your 3TB drives since you only have three of them. Since all the drives are the same size in each array you won’t have any issues.
Create separate raid pools for each group of similar drives, but don’t use raid 0 unless you just doing testing. Raid 0 will give you the most space at the highest risk or failure because if any one drive dies it will take the array with it.
Thanks for the advice!
Does anyone know of some simple instructions for setting up RAID on xcp-ng, particularly having storage RAID (even mirror) separate from the boot partition? (I understand creating a RAID during installation is possible for the system drive(s)).
The idea would be to have a small RAID 1 for the system, and then a larger RAID 1 or 5 for storage.
TIA
You could use ZFS Storage in XCP-ng | XCP-ng documentation
I really like using zfs at least in my storage systems (nexenta and now TrueNas), but there was a warning in that documentation you linked to suggesting:
WARNING
Note: If you use ZFS, assign at least 16GB RAM to avoid swapping. ZFS (in standard configuration) uses half the Dom0 RAM as cache!
I know that many people run with relatively high RAM these days, but in my case the system will have 16G and 32 if needed. I run several ESXI servers with 16 G of RAM and they perform very well for my Lab work - so I am concerned with that warning… NFS or EXT appear to both support thin provisioning and efficient storage without the warning about eating RAM for swap.
Question: In that scenario is the warning a valid concern? If so, then which would be the next best go to for local machine storage?
Keith
linux mdadm raid setup.
Here is a good step by step for using the CLI to list drive details and subsequently create a RAID and set it up to be a Storage Repository (SR):
- note even though it states here to not create a repository during installation, somehow I had inadvertently set this up when I started the XO web based wizard but cancelled. It still worked.
** the only options covered in this guide was to create EXT or LVM - I chose EXT.
https://www.reddit.com/r/homelab/comments/9jh9xi/two_raid_1_pools_in_xcpng/
Keith
