Hello
I run an XCP-ng server but I have problems none of my vms get better internet speed a 30-40 Mbps and i have 250 Mbps
But i have okay response time (1 ms) the test server is in the same city
Hello
What speeds are you getting via local interfaces?
in windows it says that they are 100Mbps but they are 1000Mbps
network nicks in my vm machine
You may have some NIC’s that are incompatible. The XCP-NG forums might be more helpful for that https://xcp-ng.org/forum/category/3/network
If the VMs are Windows guests then you’ll definitely want to load drivers (think Xen calls it XenTools? if I’m not mistaken). Otherwise it’s likely using older, more compatible NIC/disk emulation which results in horrible performance.
I primarily use Proxmox and any Windows VMs need virtio drivers setup at install to perform well.
