XCP-NG - iSCSI over VLAN interface
I spun up my first XCP-NG host this week in my home lab. It’s on a 1 liter PC with only a single NIC. I’ve always run iSCSI on it’s own VLAN, so I figured it should still be fine. I’m struggling to make this work with XCP-NG the way I did in ESXi. I set up the new network for the VLAN and set it as an NBD connection, but I’m not seeing where I assign an IP address, subnet mask, etc. I figure that is going to be needed before I’m going to be able to add the iSCSI storage. I’m sure it’s something simple I’m not seeing.
I should add that I’m running the self compiled version of Xen Orchestra.
I usually connect my storage using a dedicate NIC but this process should work for VLAN as well.
  • Under Pools Name then Network create the network with the proper VLAN attached to the correct network interface
  • The going into the Host then Network and you can assign a static IP to that interface
From there you can SSH into the XCP-NG host and make sure you can ping the iSCSI interface and then it should work.
Very nice, that worked. I was going into Pools, then Network and that did not have the option to specify IP. I feel silly.
I was able to add the volume no problem. It was formerly formatted with VMFS, so I’m guessing it will need to be reformatted or something? It’s showing 100% free space despite there being old ESXi VMs still there.
It should have formatted the iSCSI when you connected it.
Yup, took a bit for me to realize this had happened. I got it rocking now. I’m starting to think about using this at work.
Hello, how did this work out for you? I’m curious what are the benefits of booting from iSCSI for a hypervisor? Does it add unnecessary complexity?
