Having some weird issues when trying to install xcp-ng 8 on a dell r630.
Setup is a r630 with a perc h730 I believe. We’ve got 4 800gb ssds in a raid 10 config.
The issue comes in after the installer gets past “preparing for install”. It just seems to get hung up at around 20%. And then will finally fail. Last error I got was "error 30 - read only file system “/tmp/root/var/cache/yum/installer/install/cahchecookie”
This only seems to happen on this hardware when we try to install on the array we setup. It goes through just fine on a single drive, so I feel like the ISO is ok. So we are trying to figure out if maybe it’s an issue with the ssds or the controller itself. Lucky it’s a referb server with dell warranty so we can get that stuff replaced if need. Just trying to narrow some things down.
