XCP-NG import VHD slow
Installed XCP-NG 8.1 and Xen Orchestra Server 5.79.2
For the vm Storage I am using a local disk, setup with LVM. Everything is running fine but I am having troubles importing a 196 GB VHD file with the Xen Orchestra Console. It keeps saying importing. When I check the network settings its not even using 500 kbs??
The XCP-NG Server is connected to 1 GB Network and a copy of the same file over the network to our NAS takes about 35 minutes, but I seem not being able to import this.
Alternatively I thought to scp the VHD file to the datastore but don’t know how to use the physical path in LVM.
Not something I really do that often, their forums are probably a better place to ask about this Home | XCP-ng forum
No problem Tom, thank you anyway.
