I have a question about accessing the virtual enviroment in XCP-ng. I’m basing this off how Synology does web access into the virtual machines it can host with VMM. Synology has a 1-click button to generate a Share Link that gives you access to the Virtual Host. This is a console type view and not a remote access into the operating system.
No but, you could set up a user inside of Xen Orchestra and give that person “user” access to just that VM. They would have to have access to Xen orchestra and if they aren’t using a VPN to connect to you then it would have to be public facing.
@xMAXIMUSx Do you know of any other virtual host that does have this ability? Its a small use case, but I like to setup temporary software demos and provide a link for someone to jump in and test/view.
Not off the top of my head. You could probably use NoVNC but that will take a little bit of configuring. https://novnc.com/info.html
What you are asking for is pretty special and not to mention scary if you are giving free reign to a host on your network. I hope you have best practice setup for this
Getting Guacamole to run isn’t that bad, especially if you are a docker user, depoly the docker image and you are kind of done. Otherwise getting a Centos VM spun up and getting Guacamole to work isn’t too bad, would be best to have HA Proxy (or other reverse proxy) to handle the HTTPS.
