Hello folks,
Getting further into my adventures with the snappy and stable XCP-ng lab setup, I ran into a hitch trying to install the Guest tools in Linux Mint. When I go to install from the mounted ISO, I get an error:
Unknown Linux Distribution linuxmint
You should manually install a version of
xe-guest-utilities which is suitable for your
distribution.
I find some of the XCP-ng documentation scarce for the tools. This worked fine on new Debian install, but fails on Mint. Any ideas?
TIA
