I was torn between posting on the UI community or XCP-ng, so here’s my first post here where I can see both world.
I wanted an encrypted Storage Repository for XCP-ng without encrypting VMs at the OS level or buying server-grade equipment.
One solution I found was OpenMediaVault and using disk encryption with LUKS. It works great, no problem here.
However, I wanted to use a UNAS, which doesn’t support disk encryption. It does support share encryption, but NFS is disabled.
So, I used SMB for my Storage Repository on encrypted shares, and to my surprise, it works really well. It’s almost as good as NFS on an unencrypted share.
My question is, is there something I’m missing? In my opinion, SMB is pretty reliable.
My setup: UNAS 2 with 1 disk WD Red Pro 8TB. I’m only using it for storing backup (not XO, some homemade solution) and store Continuous Replication, so I don’t really need redundancy.
