SimonF
September 26, 2022, 3:29pm
1
Thanks to the excellent video I have installed XCP-NG on a DL380 but…
Where do I install XO?
There are lots of videos showing the build script but they all seem to start from having a running VM
It’s a chicken and egg situation!
How to I make the VM to install XO which will allow me to make a VM?!
Sorry if I am being particularly dull!
LTS_Tom
September 26, 2022, 4:32pm
2
If you don’t have a VM at all installed then their XOA version and use that to build your first VM.
SimonF
September 26, 2022, 6:18pm
3
OK, thank you.
Can you then switch to that and ditch the Quick Deploy VM?
Kryten
September 26, 2022, 7:16pm
4
XCP-ng Center (on your desk/laptop) is another option for building your first VM.
LTS_Tom
September 26, 2022, 10:16pm
5
Yes, create the new VM and delete the QuickDeploy.
Greg_E
September 27, 2022, 2:14pm
6
Or type this into a command line on an XCP-NG Host and it will download and install the open source version that you can run.
SimonF
September 27, 2022, 2:27pm
7
Cheers Greg, another solid answer.
I was just struggling to see the big picture:
Install XCP-NG on hardware
Quick Deploy the XOA on the new install
Use the Quick Deployed XOA to make a VM on the new install
Use the Git script to install XOA on the new VM
Delete the Quick Deployed XOA VM
Sit back and enjoy!
Thanks to all, she’s up and running
Greg_E
September 28, 2022, 1:20pm
8
I wish the supported XOA was a little cheaper, there are a few features I’d like to have but when I priced it out it would kill my budget at work. If I could get an educational discount for small networks down to like $1000 a year, I’d be able to swing that.
