Let’s say you need to emergency transfer to master one of your hosts, does each host contain the information to become master or is there something else that needs to be done?
I know with HA that at least 2 hosts keep the master info so that failover can be done rapidly, but I never thought about regular pools.
Im thinking about the case that the XOA has seized to exist, but I do have backups of the config, but not the XOA VM.
Will a fresh XOA VM be able to simply “restore” the XO config as long as the remote holding the backup is attached and XOA can read the Remote?
Or is there another train of actions needed to be performed?
I’m comming from vSphere using vSphere replication. If vCenter is lost, vSphere replication cannot be used.
No bueno. Moment 22.
In that case some under hood fiddeling was required to restore a replicated vCenter to get thing rolling.
Note, I haven tried / fiddled with this situation on XOA yet…
XO can do both backups of all the metadata of the pool and it can backup it’s own config. The files is produces can be loaded for a bare metal full restore.
I you didn’t have a pool but just wanted to standup a different xcp-ng instance from an existing one single pool, could you recreate the pool from the metadata and where are these files?
