Hi, I am in the process of doing a system refresh on my office servers. I am currently running on Proxmox but haven’t been happy with some of the performance and its web interface timing out all the time. I started down the road with a test setup of XCP-NG and am happy with it, so time to move over to a production system.
My question is how best to setup TrueNas. I have used Truenas in the past but not for VM storage. First would be TrueNas Core or Scale. Our storage requirements doesn’t grow much so don’t see a need for a while to expand beyond the space I have. With that, how best to setup the Vdev’s.
This is going to be a clean install. I have 16 bay server. I have 8 SSD (800GB) that I can put in now, then once proxmox is fully shutdown, i will have 8 more (960GB) SSD’s that I can put in. Or I can go with 1TB enterprise spinning disk. I then have 4 M.2 WD Red 500GB drives that will be on PCI riser boards. I figure one of those will be the install drive. I do have another 32GB M.2 on a riser board that I can use as the install drive if that makes more sense.
Network is all 10G. The server will have two networks. one for storage network and one as front facing.
The XCP-NG servers (5 total) have 10G network. again, one for storage network and the other as front facing.
Thank you in advanced for your help.
