Follow-Up:
I tried to add this to /etc/modprobe.d/ixgbe-options.conf:
options ixgbe allow_unsupported_sfp=1
and after doing a:
rmmod ixgbe
modprobe ixgbe
I could find this in the dmesg log:
[14:44 vmcluster04 ~]# dmesg
[ 641.481979] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.5.2
[ 641.481981] Copyright(c) 1999 - 2018 Intel Corporation.
[ 641.482211] xen: registering gsi 30 triggering 0 polarity 1
[ 641.482228] Already setup the GSI :30
[ 641.500233] ixgbe: 0000:03:00.0: ixgbe_check_options: FCoE Offload feature enabled
[ 641.500235] ixgbe: allow_unsupported_sfp Enabled
[ 641.511343] ixgbe 0000:03:00.0: failed to load because an unsupported SFP+ or QSFP module type was detected.
[ 641.511361] ixgbe 0000:03:00.0: Reload the driver after installing a supported module.
[ 641.511760] xen: registering gsi 37 triggering 0 polarity 1
[ 641.511776] Already setup the GSI :37
[ 641.532226] ixgbe: 0000:03:00.1: ixgbe_check_options: FCoE Offload feature enabled
[ 641.532227] ixgbe: allow_unsupported_sfp Enabled
[ 641.543354] ixgbe 0000:03:00.1 0000:03:00.1 (uninitialized): WARNING: Intel (R) Network Connections are quality tested using Intel (R) Ethernet Optics. Using untested modules is not support ed and may cause unstable operation or damage to the module or the adapter. Intel Corporation is not responsible for any harm caused by using untested modules.
[ 641.681819] ixgbe 0000:03:00.1: Multiqueue Enabled: Rx Queue count = 16, Tx Queue count = 16 XDP Queue count = 0
[ 641.684051] ixgbe 0000:03:00.1: 32.000 Gb/s available PCIe bandwidth (5 GT/s x8 link)
[ 641.684394] ixgbe 0000:03:00.1 eth2: MAC: 2, PHY: 17, SFP+: 6, PBA No: G28774-000
[ 641.684397] ixgbe 0000:03:00.1: a0:36:9f:27:9f:0a
[ 641.684414] ixgbe 0000:03:00.1 eth2: Enabled Features: RxQ: 16 TxQ: 16 FdirHash
[ 641.686499] ixgbe 0000:03:00.1 eth2: Intel(R) 10 Gigabit Network Connection
[ 641.731152] ixgbe 0000:03:00.1 side-4034-eth2: renamed from eth2
So, the option itself results at least in a change of behaviour, however, only one of the two 10G ports seems to be detected on PCI slot 0000:03:00.1 - the other one at 0000:03:00.0 is allegedly still equipped with an unsupported SFP module - but it’s the same one as in the other port.
Also, according to the dmesg log, one of these interfaces has been added as eth2, but when trying to acquire this interface:
[14:50 vmcluster04 ~]# ifconfig eth2
eth2: error fetching interface information: Device not found"
I have no further ideas at this stage. Any help would be appreciared!
Thanks!
