I am sure its fairly simple but does anyone happen to know the best way to go about how I can fix my Xen Orchestra from source not showing any stats anymore? It was built on Debian 11 back on the previous XC-png 8.2 release. Just wondering the best way I can fix the current Xen instance that is running as a VM on the Host. Thanks in advance!
Are both XCP-ng host(s) and the Xen Orchestra on the latest versions?
On the Xen from source “about” tab, it is stating that I am not up to date with master. I am not all that familiar with Debian just yet so what would be the path to fixing this on the VM that is on Debian 11 running the instance of XO from source? Thank you again! I am sure it’s so simple but it’s part of the learning process. hahaha
I think I am figuring it out! hahaha I love it. updating the xo-install.sh now! We shall see if this was what I was missing.
I have a video on how to build from sources but when you are updating make sure you go into the XenOrchestraInstallerUpdater directory you first do a git pull to make sure you are on the latest version before running xo-install.sh
Thank you again very much!
