X2GO issues testing on POP OS
Hello friends! I am moving over to Pop OS as my main OS soon. I wanted to set up a linux VM server and use X2GO to connect to all of my VMs.
I have the server installed on POP os to test and I am able to connect but I am having some problems.
I am connecting to it from a windows 10 PC and the remote connection is very grainy looking and I was hoping to get it crystal clear. I played with a few settings and haven’t had much luck.
also I can only get it to work in full screen mode. If I try to make the connection windowed, it will appear for a short second and then disappear but will say the connection is still live.
Does anyone have any guidance on how to solve this problem?
Did you install Gnome Flashback?" sudo apt-get install gnome-flashback
Gnome does not work properly with X2Go
I did install gnome flashback :frowning:
Has this ever been solved? I have the same problem accessing a new PopOS install with X2GO. Went through step by step, installed the gnome flasback, and the connection is droping everytime.
It don’t thinks so, and it has probably gotten worse in the meantime instead of better. BTW, the name X2go doesn’t suggest anything good for the future, as GNOME is about to drop X11 support and I don’t think X2Go works with Wayland.
See here for details about desktop environment compatibility: doc:de-compat [X2Go - everywhere@home]
TL;DR:
Use LXDE, XFCE or MATE
…or another remote desktop solution. :wink:
