Hi,
I’ve already set up several Wireguard tunnels in OPnsense (either site-to-site or a Road Warrior one) before. If you have a static public IP on the WAN interface, the setup is simple and straightforward, even if the other side (the Road warrior) has a dynamic IP or is even under CGNAT). Ok.
What if there is a dual WAN setup on OPNsense where the first WAN gets a static public IP and the second WAN only gets a dynamic IP?
I need some guidelines to start and get it right, please.
Do I need to set up two Wireguard interfaces on OPNsense and two different config file on the road warrior machine?
