WireGuard Site-to-Site broken after MODEM Reboot
My WireGuard tunnel stays down when I reboot my cable modem.
A reboot of the pfsense and it works, no problem.
Is there anything you guys can think of I need to check to get this fixed.
Thanks!
My guess is that maybe the IP address changes and Wiregaurd needs to be restarted which you can do without restarting pfsense.
Yeah I wish, but the IP address is staying the same. I have done it twice this morning and the tunnel will not come back up until I reboot pfsense.
The only thing I can think of is I have something wrong going from a static IP to a dynamic IP.
I have other Wireguard tunnels that are from static to static that work fine. But this one is a dynamic to static.
may be you should have to try to keep it on rest for atleast 5 min
Thanks, I will try that.
