Hello from Germany ![]()
I try to setup a Site to site WG VPN connection between a Fritz!Box router and a pfSense. The connection works and I can ping from both sides.
Side A with the Fritz!Box Router is working fine, ping , connection etc. works good
Side B with the pfsense, I can’t access the resources. I can ping a server on Side A but I can’t access it from the browser.
Any ideas where to look at on the pfsense? There must be a routing issue.
The Peer config for side A:
- both networks in the config as Allowed IPs
- Firewall rules are for now Any any on the LAN, WG and WG0 Interfaces.
- I have a Gateway with the IP of the WG tunnel from Side A
- a static route for the local network of Side A using the WG Gateway.
I get the following error in the pfSense logs if I try to connect from Side B to a host on port 5008 on Side A:
Default deny rule IPv4 (1000000103) WG-Tunnel-IP-SideA:5008 MY-IP-From-SideB:52765 TCP:SA
thanks in advance
regards
Lukas
