Hi
I have Wireguard setup and configured on A Windows 2019 server, I can connect from an endpoint fine to the server over the VPN.
What I can’t do is access anything other than the server that Wireguard is installed on. I added a static route in pfSense, and connecting in from a remote laptop I can ping the entire network, printers, other laptops, servers etc but I can’t access them. For example I’m trying to reach an internally hosted website on a LAN IP, which I can ping the page doesn’t display - it does on a directly connected system though. I tried accessing pfSense interface from over the VPN which also doesn’t work. Again, I get timed out. I can ping pfSense fine when connected to the VPN.
Any ideas greatly appreciated.
PS: for the sakes of testing, I added an allow all firewall rule in pfSense ok the LAN segment that the VPN lives in, which happens to be the same LAN the web server is on.
Thanks.
