Whitelist Pfblockerng
Hello,
How do I go around whitelisting a device using the local IP on my pfsense box? When I install it I lose access to my Ring camera via the Android app, however when I remove it it works again.
Secondly, I would like whitelist using this text file, however it is in Adguard format but I can edit that myself then I can upload the txt file to my cloud server;
https://raw.githubusercontent.com/hl2guide/AdGuard-Home-Whitelist/main/Modules/Organizations/microsoft_whitelist.txt
There is not a list by local IP but you can use a DHCP reservation to assign that device not to use pfsense so it bypasses pfblocker.
I don’t think you can do a whitelist feed, you have to paste it into the list.
