I’m looking for a reliable, unmanaged 16-port Gbe switch. I know it’s a wide range, any brands with a history of problems? What do you guys like?
It’s going into a school with about 20 wifi devices per port, using 6 ports total. Not much data pumping through, mostly cell phone web research or laptops using office, maybe teacher chromecasting some youtube video.
Now that I write this out, should I be concerned with uplink bottleneck??
@xmemex Personally I recommend websmart / managed switches. I havent used their dumb switches, but I guess they should be good enough.
If you arent going to do anything fancy any decent switch from HP / TP-Link / Netgear should do the job. If you are going to have heavy usage. Go for something a bit more powerful.
If you are planning on VLAN etc, its better to plan now since you will have less redundant unusable hardware.
Is it possible to use a smart switch instead of unmanaged? Atleast for future proof and for you to avoid a lot of headache in the future… A TP-Link jetstream smart switches are very affordable and efficient to use.
