Could you please help me decide which SMB FW that fits to cater only for CCTV and PA systems? They are vlan segregated. My 3 best picks are below devices. Thank you in advance on your recommendations.
Yeah, if in doubt, go with pfSense. EdgeRouter focuses more in routing although you can setup a firewall in a router. You must be familiar with setting up the three chains of the firewall that associate with a port or VLAN:
in: packets coming in to the router and routes to different networks
local: packets coming into the router only
out: packets coming in from a different network and out into the network that goes through the firewall.
For pfSense, there’s only one direction that communicates to the pfSense firewall or when routing to different networks, which is “in.” So in pfSense, the “in” and “local” is combined into one, so there’s no need to deal with separate firewall chains.
I know nothing about Firewalla but after I did some research, it seems more like a SOHO device to me. I would probably stay away from SOHO devices when dealing with CCTV and PA systems. If there are vulnerabilities in those devices, you don’t want an outside attacker to get into the CCTV/PA network.
