looking for some feedback on which firewall is better a negate pfsense firewall or fortigate 60e firewal?
Unless you need to do specific things, like a site-to-site VPN with another fortinet, they are functionally equivalent in what you can do with them. However, if you need/want IPS or some other functionality, then you have to consider that in PFSense (even if you purchase a support subcription from Netgate) things have to be set up and maintained manually, whereas on Fortinet it will be more set-and-forget because it will have updates provided daily or more frequently as part of the service plan.
If you are going to choose a proprietary firewall, don’t choose Fortigate
