I’m new to PFsense & wondered if there’s a go-to software package that can monitor multiple PFsense boxes in one dashboard. eg. firmware updates, outages, stats & notifications etc.
Thanks!
Notifications can be done via e-mail, outages you will hear about it and firmware updates are feu ‘that’s a good thing’ so you can set aside a time for all your clients. I’m sure there are packages out there but i’m guessing a third party for connection or some other means of secure connection to homebase. Not sure you will need it as I find Pfsense very stable and like I said if there are issues you will be the first to know ![]()
pfsense can use Zabbix & Nagios for monitoring and for the firmware just look for the releases. pfsense does not have different firmware for different models like other firewall vendors.
I have six sites link with a mesh of VPN, and these are the things I have done to ease the management.
- Extensive use of aliases for everything. (network ranges, ports groups, hosts)
- Consistent nomenclature for aliases.
- Alias synchronization. (manually but I plan to use the HA options)
- I have bookmarks on the browser for all internal (VPN Addresses) and public addresses. (yes, my firewalls have open ports for administration on a public interface, but I only allow connections from one specific IP)
- I have a rsyslog server that receives logs from all the firewalls.
- I use static routes to connect to the switch on each site, and OSPF for routing inside the VPN mesh.
When I add a new route, all the other firewalls get updated in a couple seconds. - Planning and network design, well defined network ranges and documentation. (I have a spreadsheet with all the information, ranges, interfaces IPs, ISPs contact numbers and services IDs.
I heard that netgate may be working on software that will manage pfsense deployments. This would be super useful in the enterprise.
Nice setup! I’m slowly moving certain documentation over to a Draw.io network diagram, with a legend & IP’s etc etc listed close to devices / via an arrow. So far so good & the clients like the diagrams which is a bonus.
