I posted this over in the Netgate Forums and thought I’d also check with folks here if anyone else knows of a solution.
Ever since upgrading to pfSense 2.7.2 CE from 2.6.0 CE, the WAN interface will lose connectivity until pfSense is rebooted. My fiber modem never goes offline and there have been no outages with my ISP. No hardware changes have taken place with the firewall. It is not virtualized.
Looking at the logs, I saw this before I rebooted the firewall:
Feb 22 08:01:31 rc.gateway_alarm 54098 >>> Gateway alarm: WAN_DHCP (Addr:x.x.x.x Alarm:1 RTT:1.046ms RTTsd:.259ms Loss:21%)
Feb 22 08:01:31 check_reload_status 438 updating dyndns WAN_DHCP
Feb 22 08:01:31 check_reload_status 438 Restarting IPsec tunnels
Feb 22 08:01:31 check_reload_status 438 Restarting OpenVPN tunnels/interfaces
Feb 22 08:01:31 check_reload_status 438 Reloading filter
Feb 22 08:01:32 php-fpm 70525 /rc.openvpn: Gateway, none 'available' for inet, use the first one configured. 'WAN_DHCP'
Feb 22 08:01:32 php-fpm 70525 /rc.openvpn: Gateway, NONE AVAILABLE
Feb 22 08:01:32 php-fpm 70525 /rc.openvpn: OpenVPN: One or more OpenVPN tunnel endpoints may have changed IP addresses. Reloading endpoints that may use WAN_DHCP.
Feb 22 08:01:32 php-fpm 26777 /rc.filter_configure_sync: GW States: One or more gateways is down, flushing all states: WAN_DHCP
I have adjusted the WAN monitoring setting in System / Advanced / Miscellaneous > State Killing on Gateway Failure to Do not kill states on gateway failure to see if this helps based on other forum posts.
If anyone has any insights on why this his happening or is a known bug with 2.7.2, would appreciate a reply. Thank you.
