I’m trying to host some of my websites using the Enhance Web Panel.
My VPS provider is OVHCloud.
I currently have two VPS instances:
One in the EU, which serves as the main server (used primarily for portal login and backups),
And another in North America (NA), which will host the actual websites.
Security Setup
I’ve secured the servers as much as I can with the following setup:
OVHCloud Edge Firewall:
SSH is running on a custom port and is blocked by default.
WireGuard is also blocked.
Both services can only be accessed from the other VPS’s public IP for internal communication.
The firewall has a limit of 20 rules, so I’ve only blocked common ports. Unfortunately, I can’t block everything since Enhance uses random custom outbound ports.
Inside the VPS:
I use UFW and Fail2Ban.
If I’m not mistaken, Enhance also comes with its own built-in firewall.
I’m using Ubuntu Pro for updates and security patches, which I got for free since I have fewer than 5 devices. Not sure how much that helps, but it’s something.
I’m also using SentinelOne for Linux, although it’s still in the process of being activated.
Public-Facing Sites:
- I use Cloudflare Proxy so attackers can’t see the real IP address of the VPS.
The main VPS (EU) acts only as a portal login and backup server; all actual hosting is done on the NA VPS.
Has anyone done something similar or faced situations like this? How did you handle it?
