trying to create a site to site vpn between a udmpro and a udr7 with no luck. Do not have any public IP available. So i am using noip to handle this part. But I have also tried the wan IP also.
I can not get a connection at all.
The UDM is on a comcast modem with ports 500 and 4500 port forwarded to the udm.
I can’t even get get openVPN to connect to it from a pc. This is tried through setting up the vpn server on the udm and taking the file and importing it into the pc. Still no connection. So I am lost on where my problem might be here. Any thoughts ??
When you say no public IP available do you mean no static IP? Or do you mean all you have is a CGNAT IP?
when I try to use site magic it shows the devices bur can not check them off and the message says no public ip
If you don’t have a public IP on both sides then you won’t be able to use site magic.
best way to approach this then?
There are quite a few ways. It depends on what you are trying to accomplish. If you are simply trying to connect to a server or services on either side you can setup something like netbird on a VPS as an example. We would need to know more about what you are trying to do to give a more granular answer.
I need to pass a local pc to another office so they can all be on the same subnet. The remote office will be using wired android devices so we need to pass this through router to router.
In that case what I would do is still use the VPS option as your middle man.
- Setup a wireguard server with this kind of config on your VPS. (Might need to omit the
MASQUERADEunless you need a specific NAT need for it.)
[Interface]
PrivateKey = <YOUR_SERVER_PRIVATE_KEY> # This is the server's private key
Address = 192.168.4.1/24 # Assign a static IP to the WireGuard interface
ListenPort = 51822 # The port WireGuard will listen on
PostUp = iptables -A FORWARD -i wg0 -j ACCEPT; iptables -A FORWARD -o wg0 -j ACCEPT; iptables -t nat -A POSTROUTING -o wg0 -j MASQUERADE
PostDown = iptables -D FORWARD -i wg0 -j ACCEPT; iptables -D FORWARD -o wg0 -j ACCEPT; iptables -t nat -D POSTROUTING -o wg0 -j MASQUERADE
- Create a WireGuard Tunnel: In the UDM Pro’s interface, you’ll create a new WireGuard tunnel.
- Peer Information:
- Private Key: The public key from the WireGuard server.
- Allowed IPs: The subnet you configured on the WireGuard server (e.g., 192.168.4.0/24).
- Routing: Configure a static route on the UDM Pro to route traffic destined for the other network through the WireGuard tunnel.
OK i will look at that thank you
Here is the more detailed outline
| Node | Role | Internal WireGuard IP | LAN Subnet |
| VPS | Server | 10.0.0.1/24 |
n/a (just a relay) |
| Site A | Client | 10.0.0.2/32 |
192.168.10.0/24 |
| Site B | Client | 10.0.0.3/32 |
192.168.20.0/24 |
1. VPS (WireGuard Server)
[Interface]
Address = 10.0.0.1/24
PrivateKey = <VPS_PRIVATE_KEY>
ListenPort = 51820
# Site A
[Peer]
PublicKey = <SITE_A_PUBLIC_KEY>
AllowedIPs = 10.0.0.2/32, 192.168.10.0/24
# Site B
[Peer]
PublicKey = <SITE_B_PUBLIC_KEY>
AllowedIPs = 10.0.0.3/32, 192.168.20.0/24
Make sure forwarding is enabled and add
net.ipv4.ip_forward=1to/etc/sysctl.conf
2. Site A Config
[Interface]
Address = 10.0.0.2/32
PrivateKey = <SITE_A_PRIVATE_KEY>
[Peer]
PublicKey = <VPS_PUBLIC_KEY>
Endpoint = your.vps.ip.address:51820
AllowedIPs = 10.0.0.0/24, 192.168.20.0/24
PersistentKeepalive = 25
Make sure to create static routes to
192.168.20.0/24via10.0.0.1
Ensure your LAN firewall on Site A allows forwarding between192.168.10.0/24 <-> wg0
3. Site B Config
[Interface]
Address = 10.0.0.3/32
PrivateKey = <SITE_B_PRIVATE_KEY>
[Peer]
AllowedIPs = 10.0.0.0/24, 192.168.10.0/24
192.168.10.0/24via10.0.0.1
Ensure your LAN firewall on Site B allows forwarding between192.168.20.0/24 <-> wg0
@LTS_Tom how does this work with unifi ??
It doesn’t, you install these on a host(s) behind the UniFi firewall.
Do you need the remote devices on the same subnet or just access to the subnet at the home location?
Rather Han site to site, would teleport work for those android devices, WiFiman app connected back to your UniFi gateway. This will work without being on a public ip
Finally got it after begging with them in Oregon office we moved the UDM to another location that I can put a modem in bridge mode. Then poof it gets done and working in just a short time. told them it would be easier if we just have done it that way in the first place lol
Thanks Everyone
