I currently have pfSense set up so that various devices and VLANs use a VPN connection and I have been noticing that the speed is significantly slower than my direct connection from my ISP. Though I expected the drop in speed I am wondering if I connect to a second or even a third VPN and group them in pfSense will it help with getting more throughput for the devices and VLANs using the VPN tunnel?
Aggregating VPN’s together in pfsense will not give you more speed.
Thanks Tom, so it would be more for failover / redundancy then.
