if you are using some sort of VOIP app on your phone and want to make calls on wi-fi is there any “best practice” when it come to the setup of the wi-fi?
i have quite mixed experience with calls on wi-fi, sometime it works perfect and sometimes not.
we can skip the part of the right ports have to be open and so on, that is a little bit more obvious thing, but is there a good way to tune the wi-fi settings for calls?
WiFi is the less than ideal transport for calls due to the WiFI being subject to interference and range issues. Great coverage with low usage density will give you a good call experience.
ok good to know, so you mean there isn´t one magic button that makes everything work on one AP ???!
(just kidding.)
