Hi
My firewall device has 4 x Gigabit ports as well as an older HPE5130 managed PoE switch.
Should I create VLAN’s on pFsense or just create different interfaces and create the VLAN’s on the switch?
Hi
I prefer to trunk the connection, in both senses of the word.
I.e., create a link aggregation with 2 or more ports and then use VLANs over that. That way, if an individual link fails, the connection between the router and switch is still operational.
I prefer trunk port to the switch and then configure the switch ports to the proper VLAN
I’ve something similar, on the router I’d keep it as WAN, LAN and the other two in LAGG to the switch for your vlans. Generally I just use the LAN as an emergency access directly to the router if I balls something up.
