As the title suggests i am doing further experimentation with pfsense in a virtualized environment and it works great.
My question is this is there a way to open up the web login interface to specific private IP addresses on the WAN side?
To be clear the wan side of the pfsense instance is behind my physical firewall so still protected from true public access. What I essentially want to do it is be able to use my desktop which is not routed through the virtual instance of pfsense to login to the control panel and be able to make changes or read logs. I realize this may be an issue if my pfsense instance was my primary firewall from a security standpoint but i have a few private addresses i would like to white list to access the web interface for the virtual pfsense is this possible , I am having issues finding help for this topic because most sites assume pfsense is at the edge of the network when in my case its at the edge of my virtual lab not the physical network.
