I am running pfSense in a VM in XCP-ng with 2 Vlans.
When I do a speed test in pfSense, I get the full 1G speed but all the VM that I run using the pfSense vlan interface are barely getting 10Mb connection to the internet.
Here is my setup
Physical host is setup with public IP
Inside the host, I have 1x pfSense with another public IP for Wan.
Inside pfSense, I then created 1 LAN network that then run my 2 vlan.
Could you anyone please help me understand what is going on?
I found the issue… I installled pfSense using Xen Orchestra template so I assumed all will be good but then I missed the step where I need to Disable TX Checksum Offload.
So how would you do it when you renting a dedicated server for a cloud provider that give you a public IP? I am not happy either about that setup but not sure of any other way. So far, i set a firewall rull to only accept ssh from my office IP and blocked https which is the hypervisor web interface to launch XOA.
