Looking at Refurbished Dell PowerEdge R710 in the 6 Bay 3.5 Inch variety. Looking at setting up xc-png on it to allow for setting up both a NAS for backups as well as a Virtual Lab for testing different Scenarios. Do you think this would be a good setup? I understand the ram it a bit of an overkill but you can’t have too much.
2 x 3.33 GHz Hex-Core Intel Xeon Processor with 12MB Cache – X5680
128GB Memory Upgrade Kit (8x16GB) 2RX4 PC3-10600R
6 x 3 TB 7200 RPM SAS Drives
I think it would be sufficient. What type of NAS you planning on virtualizing? xcp-ng doesnt require much. I think I gave the DOM like 4Gb ram. Most VM’s I’m using within xcp-ng are ubuntu which I’ve allocated 1-2Gb of ram for testing. Xen-orchestra which I set up on virtualized Ubuntu installation I allocated only 1gb which seems to work ok.
This will do, nice config. Please try to Buy from TechSupply Direct, so that LTS and @LTS_Tom can get some support.
Use OfferCode LTSERVICES to get 10% off your order at https://www.techsupplydirect.com/
the setup I currently am looking at I can get all hardware from servermonkey.com same as where tom got his lab server. Cost is right at $940 including shipping.
