I am planning to purchase a UDM Pro to replace my current USG. My question is that will the UDM Pro also fully replace my Cloud Key Gen2+ in functionality after the swap?
Thanks Guys!
Thanks Guys!
Yes, it has both the UniFi controller and the UniFi protect.
Yep, what @LTS_Tom said.
When I moved from a VM running unifi controller to Gen2+ I just backed the config up, shut down the VM, started the Gen2+ and restored the backup. It all just seemed to work.
Not done a Gen2+ to UDM Pro but I would assume the same process works.
