Can someone suggest info on how i go about updating my versions of Greylog/MongoDB without breaking them ?
It would be nice to know what your installation is. Docker? Package? What OS you are running?
Fedora Linux with Docker
What graylog version are you on? Are you using docker compose?
You update the docker config to use the latest version and then run
docker-compose pull && docker-compose up -d
I keep the docker compose I used in my video updated on GitHub
Also how does one update the MongoDB associated with Greylog ?
If you followed my install process then it is all in the same docker compose file and will update at the same time when running the pull.
great thanks for the help with this
Noticed that your .yml file contains the line mongo:6.0.5-jammy.
I think this is for Mongo Ubuntu version.
If I am using Fedora do you have any idea what I would use instead ?
You can run mongo:6.0.5-jammy on Fedora just fine. Docker images are self contained.
